kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
benfrain
Jul 20, 2009Aspirant
sibe wrote: Just replaced the stock fan in my duo a couple of days ago with a Fractal Design Silent Series 60mm fan and everything is working great! Actually it´s better than great! The duo with two 500gb barracudas installed are running much cooler now, 35-36C as opposed to 40-41C with the stock fan with no modification to the automatic fan speed controls. And the best part is; it is almost quiet! It is almost as if the disks are noisier than the fan :) I have been really annoyed about the noise of the stock fan, especially as they market the duo as quiet! "Our designers went so far as to sleep with the Duo at night to make sure it was quiet so you can be sure it can fit in discretely anywhere in your home." yea right!
My advice to everyone out there, buy a new fan! But be careful, look for a fan that moves enough air to cool your drives!
________________________________________
http://komponenttoppen.blogspot.com
Hi Sibe, are your drives still running cool enough? I'm looking to replace the stock fan with one of these:
http://www.quietpc.com/gb-en-gbp/products/60mmfans/afdp-6025b - However, I'm concerned that the CFM value looks low (13.7).
However, it is similar to the one you have installed, which on this same site lists the CFM as only 16? See here: http://www.quietpc.com/gb-en-gbp/products/fractaldesignfans/fd-fan-60
Can anyone else who has successfully quietened their Duo relate the CFM rating of the fan they have used?
