kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
axxe
Jul 29, 2009Aspirant
A word of warning: I found using a 60x80 adapter nearly impossible (this was my first plan). 2 of the 4 mounting holes for the original fan are so close to the side of the unit that it's impossible to put the side cover on once the adapter is mounted to the back case. I puzzled over the order of assembly for a long time, trying different configurations of mounting hardware, and ended up cutting open the back of the case and mounting the 80mm fan directly to it.
A different style of adapter might have worked, I suppose.
