kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
ernhamDjinn
Aug 02, 2009Aspirant
jraneses wrote: In looking at possible replacement fans for the Duo on Newegg, these models might be viable candidates. In my opinion, it's not so much the noise level of the Duo that's the problem, it's the tone of the stock Crown fan.
VANTEC TF6025
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999615
Dynatron DF126025PL-3/4G
http://www.newegg.com/Product/Product.aspx?Item=N82E16835114064
Those are the top 2 rated 60mm fans from the product category
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2000110573+1372726523&Configurator=&Subcategory=573&description=&Ntk=&SpeTabStoreType=&srchInDesc=
Can any of the Jedi's comment on the compatibility of the replacement fans listed above?
Thanks,
Jason
Be careful with the connectors the fan you purchase provides. The VANTEC TF2065 comes with a 3/4 pin connector, but the 3-pin connector does not work - it doesn't power the fan. You would have to purchase an adapter, and the two 4-pin connectors that come standard with the fan already take a bit of space. I purchased that fan but will return it since it cannot work in the unit.
http://www.frozencpu.com has a TON of different fans and fan accessories. I was wondering if buying a simple rubber fan silencer wouldn't do the trick. It seems to me that a lot of the noise caused by the fan is the vibration of the back plate the fan is attached to.
