kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
bbear
Aug 08, 2009Aspirant
I've seen some 60mm to 92mm fan adapters - the same thickness as the 60 to 80mm ones. I was wondering if anyone knows if a 92mm fan would fit on the Duo? If so, it certainly could be more airflow for lower RPMs and potentially quieter.
