kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
DiWa
Nov 09, 2009Aspirant
Hi all,
Let me share my own experience on the subject as I also experienced this disturbant, unacceptable noise in my living room :evil: .
I read a lot of posts and changing the fan for a bigger one seems to be THE solution.
Still, it was not exactly acceptable for me, for a pure design POV.
The Duo is quite pretty and didn't want to change it :wink:
:idea: So I scratched up old post on overclocking & heat management on PC Case and this is the recipe:
The result is really surprising as my Duo is now silent and I don't ear it anymore.
No need to buy a new fan, just screws for about 1 or 2€.
Enjoy
DiWa
- * The first step is to remove the case fan finger guard to ease air flow and avoid whistle. I removed it easily with pliers
- * The second step is to use rubber screws to fix the fan
Enjoy
DiWa
