kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
exrazorfish
Nov 19, 2009Aspirant
Ennio wrote:
Why are you all so hooked on Noctua fans? They're not the most silent fans out there, considering their air-flow.
No particular reason. It felt important to me that the fan had a good track record for this particular mod, which the Noctua NF-R8 had, but if you shop around for silent fans the market is huge. The Noctua is widely available and is good priced. Important except for the noise level is the amount of air it moves (which ofcourse should match or exceed that of the stock fan).
What did you set your minimum fan rpm speed at and how did you arrive at that value?
