kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
You_never_know_
Jan 20, 2010Aspirant
Hi guys,
I´m unhappy with the noise of my DUO too. I´ve seen the link to the french thread but I couldn´t got it managed to translate it properly.
Thanks for the ideas you posted here, but can it be true there´s no quiet 60mm fan to replace just the original? Did someone had success with the Papst fans? or other ideas?
thanks
cheers
YNK
thanks
cheers
YNK
