kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
plastiqmanb
Feb 01, 2010Aspirant
ahh yes razor, I did not check the crown spec before I ordered the other one (i honestly did not think much of a difference compared to voltage/amps)
So far all is well but my duo is not on 24/7. 86F is the average temp with a large copy job and a HD stream going. :)
