kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
Pjotr1
Feb 28, 2010Aspirant
Don’t use them and use normal screws. I have a Nexus 8 cm screwed on the back and it is really silent, no noticeable induced vibration/noise at all to the case of the DUO.
