kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
mrkalel
Mar 21, 2010Aspirant
Daryn wrote: I have my duo in my family room and it was clearly audible 12' across the room when idle. It was very annoying when under any load because it was often louder than the tv. My wife kept telling me to get it out of the room.
I just installed a Noctua NF-R8. All I can say is: WOW! Initially, I thought the fan was defective since it was virtually silent during startup and didn't feel like it was pushing much air. I recalibrated the fan and I thought the calibration wasn't working since again the fan was silent. I'm used to the hairdryer of the stock Crown fan.
The fan is perfectly fine, and the drives run at 34C instead of 40C+. My duo is now the quietest thing in my home theater. It's quieter than the DVR and PS3. My wife thought I was wasting more money until she heard, or actually couldn't hear!, the duo.
I bought a Noctua NF-R8, 60mm to 80mm adapter, and a fan grill for $20 + shipping from coolerguys.com. I had to use a utility blade to shave a little bit of plastic off the corners of the adapter so the side panel would slide back on. If you are reading this thread, get this fan, you definitely won't regret it.
Sorry for the poor picture quality, but I'm too lazy to take it again.
I just purchased everything I think I needed from Coolerguys...but picked the wrong shipping so I prob wont see everything till Fri.... As soon as I get everything I will post results... thaanks again guys!
