kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
John_Bean
Sep 07, 2010Aspirant
pofrani wrote: just curious... is it possible to change the stock fan and replace it with something better.... then swap the stock fan back into the unit in case for warranty repairs?
Of course it's possible - if it's a plug-in replacement like the Fractal I used. No modifications needed.
