kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
jetsetwilly1
Sep 08, 2010Aspirant
Use a pin or similar to poke into the plastic interconnect and release the metal prongs - no need to cut the wires. Then just slip the cable through and re-attach the plastic connector.
