kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
pofrani
Sep 10, 2010Aspirant
John Bean wrote:
bahman wrote: does the Fractual Design fan cool better or worse than the stock fan?
Not a lot of difference. I get roughly the same temperature but at a lower fan speed from the Fractal in my Duo. The spec shows the Fractal to have a lower output than the stock fan in theory but in practice if anything the reverse appears to be true. Best £5 I've spent recently ;-)
where did you get your fractal from? i can't even see £5 on ebay :(
