kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
supertix
Oct 11, 2010Aspirant
hi to all :)
i have just installed in my ReadyNas Duo a NOCTUA NF-R8 80mm with Akasa fan adapter 60mm->80mm, and it works very fine. Noise level now is reduced and disks are colder.
But i have 2 questions:
1) following user posts pictures i have installed the fan PULLING OUT the air, is it the right installation direction? i have this doubt becase i can't remember how was installed the original fan...pulling air out or in??
2) for people with my NOCTUA 80mm fan: do you have used LNA or ULNA cables? i have installed LNA, so my fan speed is 1200rpm, 10db noise level, and disks are 30 degrees. Has anyone tried ULNA configuration? Is too poor cold air or i can try?
thanks guys! ;-)
thanks guys! ;-)
