kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
eton
Dec 01, 2010Luminary
@supertix
Yes the fan should pull out the air. That's why there are holes in the hard drive door at the front.
You might not need the Noctua cables, you can experiment with the EnableFanMinRPMOverride add-on
http://www.readynas.com/?page_id=617
