kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
eton
Dec 01, 2010Luminary
http://www.bit-tech.net/hardware/coolin ... case-fan/1
The be quiet - SilentWings USC - might be the worlds best 120 mm fan.
http://www.be-quiet.net/be-quiet.net/in ... iteLang=en
I will try it
I will try it
