kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
hadaak
Dec 27, 2010Aspirant
I bought my Duo last friday. I haven't read this thread before buying.
I did find out that the fan is noisy and just ordered a Papst fan : 38€ :-( (shipping included)
http://www.ebmpapst.com/en/products/compact-fans/axial-compact-fans/axial_compact_fans_detail.php?pID=53780
Technical description
Approval VDE, CSA, UL, CE
Bearing Sintec sleeve bearing
Connection line Single strands AWG 22, TR 64, bared and tin-plated.
Dimensions 60 x 60 x 25 mm
Direction of air flow Air exhaust over bars
Direction of protection Right, looking at rotor
General description Suitable for use at high ambient temperatures. Electronic commutation completely integrated.
Housing material Fiberglass-reinforced PBTP plastic
Lifetime L10 at 40 °C 80000 h
Lifetime L10 at maximum temperature 32500 h
Locked-rotor protection With electronic blocking and overload protection
Mass 0.066 kg
Material of impeller Fiberglass-reinforced PA plastic
Motor protection Protected against reverse polarity and locking.
Nominal voltage [VDC] 12
Nominal voltage range [VDC] 8 .. 15
Speed [min-1] 3000
Power input [W] 0.7
Min. ambient temperature [°C] -20
Max. ambient temperature [°C] 80
Air flow [m3/h] 25
Sound power level 3.9
Sound pressure level [dB(A)] 19
Wil update you when I install it.
Mass 0.066 kg
Speed [min-1] 3000
Power input [W] 0.7
Air flow [m3/h] 25
