kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
csouthon
Jan 24, 2011Aspirant
I have also installed the Fractal Design 60mm fan. The most complex piece was finding the right screwdriver!
It's been installed for a couple of weeks now and is significantly quieter than the stock fan. In terms of temperatures they seem a bit lower than the stock fan
Disk 1 Seagate ST3500418AS 465 GB , 30 C / 86 F
Disk 2 Seagate ST3500418AS 465 GB , 29 C / 84 F
Fan 1 1630 RPM
All in all I think this is an excellent upgrade
Fan 1 1630 RPM
