kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
Sulu
Jun 06, 2011Aspirant
I have joined the many who have replaced the stock ReadyNAS Duo fan with an aftermarket fan. I have to say that the noise difference is dramatic and well worth it. However I am worried about the potential for problems after getting thoroughly confused by this thread which goes into much more detail about matching the CFM, RPM and wattage between the stock fan and an aftermarket fan. Instead of trying to understand all of this, I took a leap of faith. I followed the many users in this thread who have had success with the Fractal Design 60mm Silent Series fan http://fractal-design.com/?view=product&category=4&prod=15.
For those of you in the US looking for a place to buy this fan, I couldn't find any place that had reasonable prices and availability. I would like to recommend Quiet PC http://www.quietpc.com/gb-en-gbp/products/fractaldesignfans/fd-fan-60 located in the UK. Simply change your country and currency in the upper left corner of the site and you can see that the Fractal Design fan will cost you $11.33 shipped. My fan arrived in less than a week which is faster than some domestic deliveries and the shipping price is great for international.
Prior to installing the fan I took a screenshot of my Duo's Health tab in Frontview. I run two Seagate ST3500630AS 500GB drives in my setup. I don't have any streaming services running, I simply use it as a file server at this time.
The temps and fan speed using the stock fan at the time I took the screenshot were:
I realize that this fans RPM fluctuates based temperature, but I know that it has been around 1700 RPM in the past when I have checked. I also have my HD's set to go into sleep mode after periods of not being used.
Following the nice video guide uploaded by danielrc15 http://www.youtube.com/watch?v=_68Bw2qgN4E I was able to install the new fan in a few minutes. It is really simple, and the only note I would make is that the Fractal Fan has a much longer cable so I wrapped it conveniently around the fans outer frame which keeps the cable away from any of the electrical parts on the board.
After reconnecting my Duo and starting Frontview, I proceeded to recalibrate the fan once. After waiting for a period of time for the hard drives to heat up here are the results:
The one question I have is regarding the minimum fan speed. I am aware that there is a minimum fan speed utility posted on Netgears site with some rather ominous warnings http://www.readynas.com/?p=4216 . My Duo seems to be fine when the hard drives have been running for a few minutes and the fan RPM settles. I am concerned that when the HD's go to sleep, that the minimum fan speed is dropping to around 1000 RPM as the fan barely produces enough air to feel it blowing out of the back and upon initial FrontView access when the HD's were sleeping and prior to them fully heating up, I can check the health and see RPM's around 1300 or less on the fan even though the HD temps are much cooler like 25 C and 28 C. Should this be acceptable fan speed reduction as long as the HD's are in sleep mode or should I be concerned enough to apply the "discouraged use" minimum fan speed addon and set it to around 1300?
Thanks for the great thread and any helpful advice. :D I wish I could post links using BBCode... :(
- 1704 RPM
- 42 C / 107 F
- 37 C / 98 F
- the fan speed settles between 1630 -1650 RPM
- my HD temps are 40 C / 104 F and 35C / 95 F
- the noise levels are lower.
- This is on a cool day so I am sure the temps will rise along with the fan RPM when summer hits.
