kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
Pjotr1
Jun 08, 2011Aspirant
No not all, follow the guidelines given to install the utility and restart.
Then in Frontview under System --> Power you will find "Fan RPM Override Option". You can set there minimum fan speed as desired and "Apply". That's it.
The "Danger" is that you set fan speed too low. I.e. if the noise of your fan is perfectly acceptable at 1800 Rpm then don't set it lower.
