kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
frkeller1
Jan 24, 2012Aspirant
I don't know if this applies your case, but here is how I opened my ReadyNas Duo case. Remove the four tiny screws from around the edge of the back of the unit. You can optionally remove the foot pads from the bottom of the unit in order to reduce the friction when you slide back the side panel. Then slide the side panel away from the front of the box, towards the back. It was pretty stiff on my unit, and I had to work at it a little bit. For access to the memory chip, you only need to remove the left hand panel (looking at the box from the front).
