kwantai
Oct 29, 2008Aspirant
Replacing the fan in ReadyNAS Duo - possible?
Hello. Has anyone replaced/changed the (stock) fan in the Netgear ReadyNAS duo? I would like to do this, since I think the fan makes far too much noise. Any comments and thoughts about this is w...
Jan 09, 2013Guru - Experienced User
If you purchased the duo in July 2011, then it would still be under warranty, so that would be another option for you.
