getads
Aug 28, 2013Aspirant
Replicate 314 to a NV+
Hi all, Just upgraded from my trusty readynas NV+ to a 314 (both with 4 2Tb drives). Had a question - is it possible to backup the entire 8TB on my 314 to the NV+? Can Replicate work like that? ...
mdgm-ntgr
Aug 29, 2013NETGEAR Employee Retired
I would do the first Rsync on your LAN (after the backup job has run you would edit the backup job properties).
To backup your Time Machine data you would need to select Volume C with the path ".timemachine" as the source on the NV+
