BernyB's avatar
BernyB
Tutor
Feb 22, 2017
Replicate config backup
Hi,
The Replicate portal should really really really have an option to save or reload a configuration file because on any problem, we have to enter backup jobs manually with the exact same names, and this is quite painfull.
Thank you.
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello BernyB,
    Your idea to improve the quality and functionality of the product is very much appreciated, we thank you for sharing and interest in this. You may also post suggestions and ideas at the Idea Exchange board. Adding kudos to the ideas will help as development team will be reviewing the post that has the most kudos for considering it to add to the product's future functionality.
    We appreciate your contribution to the community!
    • BernyB's avatar
      BernyB
      Tutor
      Hi,
      I lost my Replicate config again, because it stopped after an extended power outage and I had to go to the remote location to deregister&register the replicate service ONCE AGAIN. Then I have to rebuild all my backup jobs ONCE AGAIN because the service cannot remember them.
      Is there any way to make that interface more RELIABLE ?   Should I use an other method to backup my main NAS ?
      :robotmad:
      Bern
      • Marty_M's avatar
        Marty_M
        Hello BernyB,
        There is no option to backup the configuration of the backup job on the Readynas Replicate server. You may want to raise the concern to our Idea Exchange board, if it does get a lot of kudos the engineering might review and might consider adding the feature in the Replicate server.
        Marty_M
        NETGEAR Community Team
ProSupport for Business
