Stanman130's avatar
Apr 02, 2015
Request for OS6: Bacula
There used to be a Bacula Add-on for the older ReadyNAS versions, but it doesn't appear to be available for OS6. Would it be better to install it directly as a Linux package? Or is there an add-on package somewhere? If not, can one be developed?
What I'm trying to do is back up a ReadyNAS 314 running OS 6.2.x to an external drive attached to the eSATA port. Would another add-on or software be better for this? I'd like to be able to do a full backup once every few months with weekly differential backups (everything changed since the full).
Thanks for your help,
Stan
1 Reply
  • StephenB's avatar
    You could alternatively use the built-in backup (perhaps rsync).
ProSupport for Business
