rnas_newbie
Mar 10, 2013Aspirant
request:stable FTP server on DuoV2
quite a simple request; Please can we have a stable FTP server on the DuoV2. Currently on 5.3.7 it fails to work if you leave your unit on for more than a day or so. It fails to list the contents...
rnas_newbie
Mar 11, 2013Aspirant
de niro wrote: to list directory correctly you need to set masquerade address and open its port range to the internet,did you try active mode to your FTP server?
thanks for the heads up, unfortunately I use masquerading as I only need to access internally on the network (all static ip addresses)
I assume yours if fairly stable and does not suffer from the same issue?
(I will try active mode soon, to see what the results are like, may be a day or so due to the issues below)
What does seem related - is the old classic of the V2 keeps randomly rescanning the dlna from scratch, even though I do not add content and it's not set to auto update.
My main frustration stems from the issue persisting even after a reboot, unless I mess with the permissions on 'any' folder, only then does FTP work on the v2,
ps - my Ultra is fine, never an issue (my NVX that eats disks on radiator 4.2.22...is another issue)
thanks again for the suggestion :)
