bestgo
Dec 28, 2014Guide
[Resolved]dim the led light on the front panel of my RN102
i just want to dim the led light a little on the front panel of my RN102, a cmd under shell is ok, is that possible ?
- StephenBGuru - Experienced UserI don't think you can dim it, but you can turn it off. There's a ssh command in this thread: https://www.readynas.com/forum/viewtopi ... 94#p394354
- bestgoGuide
StephenB wrote: I don't think you can dim it, but you can turn it off. There's a ssh command in this thread: https://www.readynas.com/forum/viewtopic.php?f=7&t=70994#p394354
tried it, seems it's only can be turn on/off the following led lights, although the max value is 255 in max_brightness.
the act led is always on, and should be the the brightest, which seems could not be off.
/sys/class/leds/backup/brightness
/sys/class/leds/power/brightness
/sys/class/leds/SATA1_PRESENT/brightness
-thanks
