Squazz
Aug 19, 2015Aspirant
Restyling admin area
I have a ReadyNas pro 4 with OS4.
Is it in any way possible to restyle the admin area?
I can handle the styles myself, but I'm not quite sure if it's possible to replace the CSS files on the ReadyNAS?
Perhaps consider shifting to OS 6???
- SquazzAspirant
But, I cannot upgrade my firmware? It tells me that I'm running the latest firmware?
Well, you can - although its not supported.
There are instructions here, but you need to search for them. The process is destructive, so you would need a full backup (and restore your data afterwards).
