ambilik
Oct 02, 2018Aspirant
Resync not starting after disk replacement
Had disk 4 failure Monday evening. Went to replace it today and when removing the failed disk there was no notice of disk removed. Replaced with new disk of same specs and no ntoification of disk r...
Oct 02, 2018Guru - Experienced User
I''d remove the new disk and reboot. Then hot insert it again.
ambilik wrote:
or should all information be backed up off unit first?
I do recommend backing up the data. It is not protected during the resync unless you are running RAID-6
ambilik
Oct 11, 2018Aspirant
Thank you for the support. I figured that this was what was needed but you advice solidified that feeling. Went ahead and did exactly that and worked flawlessly. Thanks again.
