Ken6432-1's avatar
May 13, 2020
RN104 Resync Speed on 3rd Drive Replacement Very Slow
I am updating my RN104 from 4 8Tb drives to 4 10Tb drives.  After replacing the first drive, the resync took a couple of days to complete.  After replacing the second drive, about the same length of time.  Now, I have replaced the third drive and the resync is going very, very slowly.  After two days it is only at 53.7% and the estimate says it has 1240 hours to go.  Is this normal?  When I have updated drives in the past, each drive took about the same time to resync.  This is the first time I can remember one drive taking so much longer than others.
Thanks.
  • I rebooted the NAS and the resync speed increased to about 14 Mb/sec.  I don't know what was causing the slow down before.
    I do have backup jobs running Rsync.  This particular NAS does not have any backups configured on it, but it is the NAS that recieves backups from another NAS.
  • StephenB's avatar
    That is unusually slow. Is the NAS doing something else (backup jobs, scheduled maintenance activities, or under a heavier usage then other times)?  Resync is a lower priority task than other things, so it will run slower when there is more going on.
    I suggest downloading the log zip file, and looking for disk errors in system.log and kernel.log
    If ssh is enabled, you can get a better sense of the progress with cat /proc/mdstat and query the smart stats interactively with smartctl.
    • Ken6432-1's avatar
      Ken6432-1
      Star
      No backups running at this time although there were some running during the sync so maybe that was slowing things some.
      In the kernel.log I see a large number of ethernet errors:
      May 13 00:36:55 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=512
      May 13 00:36:55 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=896
      May 13 00:39:03 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
      May 13 00:39:04 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
      May 13 00:39:04 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
      May 13 00:39:09 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=896
      May 13 00:39:10 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
      May 13 00:39:10 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
      May 13 00:39:11 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
      May 13 00:39:12 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
      May 13 00:39:12 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
      May 13 00:39:12 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=768
      May 13 00:39:13 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
      May 13 00:39:13 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
      May 13 00:39:14 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
      May 13 00:39:15 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=144
      May 13 00:39:17 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
      May 13 00:39:25 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
      May 13 00:39:32 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
      May 13 00:39:37 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=144
      May 13 00:39:37 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
      May 13 00:39:38 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=504
      May 13 00:39:39 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
      May 13 00:39:40 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
      May 13 00:39:40 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1280
      May 13 00:39:40 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=768
      May 13 00:39:42 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0d830000 (overrun error), size=16
      May 13 00:39:43 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
      May 13 00:39:48 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=896
      May 13 00:39:48 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=768
      May 13 00:39:54 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=272
      May 13 00:39:57 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
      May 13 00:40:07 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=400
      May 13 00:40:10 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
      May 13 00:40:18 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
      May 13 00:40:20 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0d830000 (overrun error), size=16
      May 13 00:40:32 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
      May 13 00:40:34 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1152
      May 13 00:40:37 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=272
      May 13 00:40:47 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=896
      May 13 00:40:57 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
      May 13 00:40:57 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=440
      May 13 00:40:58 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
      May 13 00:41:04 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=768
      May 13 00:41:17 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
      May 13 00:41:20 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
      May 13 00:41:20 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
      May 13 00:41:21 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=896
      May 13 00:41:26 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
      May 13 00:41:28 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
      May 13 00:41:29 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
      May 13 00:41:29 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=896
      May 13 11:43:56 Media-Backup kernel: nr_pdflush_threads exported in /proc is scheduled for removal
      I wouldn't think this would impact the sync speed, though.
      In the system.log I see a number of failed log in attempts which is strange.  Some of them say the attempt is coming from 192.168.1.1 which would be the gateway server, correct?
      May 12 21:46:38 Media-Backup sshd[3419]: Invalid user Retford from 192.168.1.1
      May 12 21:46:38 Media-Backup sshd[3419]: input_userauth_request: invalid user Retford [preauth]
      May 12 21:46:38 Media-Backup sshd[3419]: pam_unix(sshd:auth): check pass; user unknown
      May 12 21:46:38 Media-Backup sshd[3419]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=gateway
      May 12 21:46:38 Media-Backup sshd[3420]: SSH: Server;Ltype: Authname;Remote: 192.168.1.1-59610;Name: root [preauth]
      May 12 21:46:38 Media-Backup sshd[3420]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=gateway user=root
      May 12 21:46:39 Media-Backup sshd[3421]: SSH: Server;Ltype: Authname;Remote: 192.168.1.1-59611;Name: [preauth]
      May 12 21:46:39 Media-Backup sshd[3421]: Invalid user from 192.168.1.1
      May 12 21:46:39 Media-Backup sshd[3421]: input_userauth_request: invalid user [preauth]
      May 12 21:46:39 Media-Backup sshd[3421]: Failed none for invalid user from 192.168.1.1 port 59611 ssh2
      May 12 21:46:39 Media-Backup sshd[3421]: Connection closed by 192.168.1.1 [preauth]
      Does this tell you anything?
      Ken6432-1
      Star
      The cat command gives:
      Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
      md1 : active raid10 sdd2[3] sdc2[2] sdb2[1] sda2[0]
      1044480 blocks super 1.2 512K chunks 2 near-copies [4/4] [UUUU]
      md125 : active raid1 sdd5[0] sdc5[1]
      1952278144 blocks super 1.2 [2/2] [UU]
      md126 : active raid5 sdb4[6] sdd4[4] sda4[3] sdc4[5]
      11720633664 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/3] [UU_U]
      resync=DELAYED
      md127 : active raid5 sdb3[6] sda3[7] sdd3[4] sdc3[5]
      11706500352 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/3] [U_UU]
      [================>....] recovery = 84.3% (3290015080/3902166784) finish=7 593.8min speed=1343K/sec
      bitmap: 0/30 pages [0KB], 65536KB chunk
      md0 : active raid1 sdb1[6] sda1[7] sdd1[4] sdc1[5]
      4190208 blocks super 1.2 [4/4] [UUUU]
      unused devices: <none>
      The resync=DELAYED is interesting.  What does this mean?
      Thanks again for you help.
      • Sandshark's avatar
        Sandshark
        Sensei
        You have a multi-layer volume due to incremental drive size upgrades.  Each layer is it's own RAID, and it can only sync one at a time.  So the delayed one is waiting for the another to complete.  The multiple layers may be contributing to the slower speed.
ProSupport for Business
