Ken6432-1
May 13, 2020Star
RN104 Resync Speed on 3rd Drive Replacement Very Slow
I am updating my RN104 from 4 8Tb drives to 4 10Tb drives. After replacing the first drive, the resync took a couple of days to complete. After replacing the second drive, about the same length of ...
- May 15, 2020
I rebooted the NAS and the resync speed increased to about 14 Mb/sec. I don't know what was causing the slow down before.
I do have backup jobs running Rsync. This particular NAS does not have any backups configured on it, but it is the NAS that recieves backups from another NAS.
May 13, 2020Guru - Experienced User
Ken6432-1 wrote:
After two days it is only at 53.7% and the estimate says it has 1240 hours to go. Is this normal?
That is unusually slow. Is the NAS doing something else (backup jobs, scheduled maintenance activities, or under a heavier usage then other times)? Resync is a lower priority task than other things, so it will run slower when there is more going on.
I suggest downloading the log zip file, and looking for disk errors in system.log and kernel.log
If ssh is enabled, you can get a better sense of the progress with cat /proc/mdstat and query the smart stats interactively with smartctl.
Ken6432-1
May 13, 2020Star
No backups running at this time although there were some running during the sync so maybe that was slowing things some.
In the kernel.log I see a large number of ethernet errors:
May 13 00:36:55 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=512
May 13 00:36:55 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=896
May 13 00:39:03 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:39:04 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:39:04 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
May 13 00:39:09 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=896
May 13 00:39:10 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:39:10 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
May 13 00:39:11 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:39:12 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
May 13 00:39:12 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:39:12 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=768
May 13 00:39:13 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:39:13 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
May 13 00:39:14 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
May 13 00:39:15 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=144
May 13 00:39:17 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:39:25 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
May 13 00:39:32 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
May 13 00:39:37 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=144
May 13 00:39:37 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
May 13 00:39:38 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=504
May 13 00:39:39 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
May 13 00:39:40 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
May 13 00:39:40 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1280
May 13 00:39:40 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=768
May 13 00:39:42 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0d830000 (overrun error), size=16
May 13 00:39:43 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
May 13 00:39:48 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=896
May 13 00:39:48 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=768
May 13 00:39:54 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=272
May 13 00:39:57 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:40:07 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=400
May 13 00:40:10 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:40:18 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:40:20 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0d830000 (overrun error), size=16
May 13 00:40:32 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:40:34 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1152
May 13 00:40:37 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=272
May 13 00:40:47 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=896
May 13 00:40:57 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:40:57 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=440
May 13 00:40:58 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
May 13 00:41:04 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=768
May 13 00:41:17 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
May 13 00:41:20 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:41:20 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
May 13 00:41:21 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=896
May 13 00:41:26 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
May 13 00:41:28 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
May 13 00:41:29 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:41:29 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=896
May 13 11:43:56 Media-Backup kernel: nr_pdflush_threads exported in /proc is scheduled for removal
I wouldn't think this would impact the sync speed, though.
In the system.log I see a number of failed log in attempts which is strange. Some of them say the attempt is coming from 192.168.1.1 which would be the gateway server, correct?
May 12 21:46:38 Media-Backup sshd[3419]: Invalid user Retford from 192.168.1.1
May 12 21:46:38 Media-Backup sshd[3419]: input_userauth_request: invalid user Retford [preauth]
May 12 21:46:38 Media-Backup sshd[3419]: pam_unix(sshd:auth): check pass; user unknown
May 12 21:46:38 Media-Backup sshd[3419]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=gateway
May 12 21:46:38 Media-Backup sshd[3420]: SSH: Server;Ltype: Authname;Remote: 192.168.1.1-59610;Name: root [preauth]
May 12 21:46:38 Media-Backup sshd[3420]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=gateway user=root
May 12 21:46:39 Media-Backup sshd[3421]: SSH: Server;Ltype: Authname;Remote: 192.168.1.1-59611;Name: [preauth]
May 12 21:46:39 Media-Backup sshd[3421]: Invalid user from 192.168.1.1
May 12 21:46:39 Media-Backup sshd[3421]: input_userauth_request: invalid user [preauth]
May 12 21:46:39 Media-Backup sshd[3421]: Failed none for invalid user from 192.168.1.1 port 59611 ssh2
May 12 21:46:39 Media-Backup sshd[3421]: Connection closed by 192.168.1.1 [preauth]
Does this tell you anything?
