Ken6432-1
May 13, 2020Star
RN104 Resync Speed on 3rd Drive Replacement Very Slow
I am updating my RN104 from 4 8Tb drives to 4 10Tb drives. After replacing the first drive, the resync took a couple of days to complete. After replacing the second drive, about the same length of ...
- May 15, 2020
I rebooted the NAS and the resync speed increased to about 14 Mb/sec. I don't know what was causing the slow down before.
I do have backup jobs running Rsync. This particular NAS does not have any backups configured on it, but it is the NAS that recieves backups from another NAS.
May 13, 2020Guru - Experienced User
Ken6432-1 wrote:
After two days it is only at 53.7% and the estimate says it has 1240 hours to go. Is this normal?
That is unusually slow. Is the NAS doing something else (backup jobs, scheduled maintenance activities, or under a heavier usage then other times)? Resync is a lower priority task than other things, so it will run slower when there is more going on.
I suggest downloading the log zip file, and looking for disk errors in system.log and kernel.log
If ssh is enabled, you can get a better sense of the progress with cat /proc/mdstat and query the smart stats interactively with smartctl.
- Ken6432-1May 13, 2020Star
No backups running at this time although there were some running during the sync so maybe that was slowing things some.
In the kernel.log I see a large number of ethernet errors:
May 13 00:36:55 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=512
May 13 00:36:55 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=896
May 13 00:39:03 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:39:04 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:39:04 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
May 13 00:39:09 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=896
May 13 00:39:10 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:39:10 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
May 13 00:39:11 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:39:12 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
May 13 00:39:12 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:39:12 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=768
May 13 00:39:13 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:39:13 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
May 13 00:39:14 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
May 13 00:39:15 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=144
May 13 00:39:17 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:39:25 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
May 13 00:39:32 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
May 13 00:39:37 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=144
May 13 00:39:37 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
May 13 00:39:38 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=504
May 13 00:39:39 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
May 13 00:39:40 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
May 13 00:39:40 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1280
May 13 00:39:40 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=768
May 13 00:39:42 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0d830000 (overrun error), size=16
May 13 00:39:43 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
May 13 00:39:48 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=896
May 13 00:39:48 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=768
May 13 00:39:54 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=272
May 13 00:39:57 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:40:07 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=400
May 13 00:40:10 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:40:18 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:40:20 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0d830000 (overrun error), size=16
May 13 00:40:32 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:40:34 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1152
May 13 00:40:37 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=272
May 13 00:40:47 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=896
May 13 00:40:57 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:40:57 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=440
May 13 00:40:58 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
May 13 00:41:04 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=768
May 13 00:41:17 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
May 13 00:41:20 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:41:20 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=640
May 13 00:41:21 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=896
May 13 00:41:26 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
May 13 00:41:28 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=1024
May 13 00:41:29 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=448
May 13 00:41:29 Media-Backup kernel: mvneta d0070000.ethernet eth0: bad rx status 0f830000 (overrun error), size=896
May 13 11:43:56 Media-Backup kernel: nr_pdflush_threads exported in /proc is scheduled for removalI wouldn't think this would impact the sync speed, though.
In the system.log I see a number of failed log in attempts which is strange. Some of them say the attempt is coming from 192.168.1.1 which would be the gateway server, correct?
May 12 21:46:38 Media-Backup sshd[3419]: Invalid user Retford from 192.168.1.1
May 12 21:46:38 Media-Backup sshd[3419]: input_userauth_request: invalid user Retford [preauth]
May 12 21:46:38 Media-Backup sshd[3419]: pam_unix(sshd:auth): check pass; user unknown
May 12 21:46:38 Media-Backup sshd[3419]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=gateway
May 12 21:46:38 Media-Backup sshd[3420]: SSH: Server;Ltype: Authname;Remote: 192.168.1.1-59610;Name: root [preauth]
May 12 21:46:38 Media-Backup sshd[3420]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=gateway user=root
May 12 21:46:39 Media-Backup sshd[3421]: SSH: Server;Ltype: Authname;Remote: 192.168.1.1-59611;Name: [preauth]
May 12 21:46:39 Media-Backup sshd[3421]: Invalid user from 192.168.1.1
May 12 21:46:39 Media-Backup sshd[3421]: input_userauth_request: invalid user [preauth]
May 12 21:46:39 Media-Backup sshd[3421]: Failed none for invalid user from 192.168.1.1 port 59611 ssh2
May 12 21:46:39 Media-Backup sshd[3421]: Connection closed by 192.168.1.1 [preauth]Does this tell you anything?
The cat command gives:
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md1 : active raid10 sdd2[3] sdc2[2] sdb2[1] sda2[0]
1044480 blocks super 1.2 512K chunks 2 near-copies [4/4] [UUUU]md125 : active raid1 sdd5[0] sdc5[1]
1952278144 blocks super 1.2 [2/2] [UU]md126 : active raid5 sdb4[6] sdd4[4] sda4[3] sdc4[5]
11720633664 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/3] [UU_U]
resync=DELAYEDmd127 : active raid5 sdb3[6] sda3[7] sdd3[4] sdc3[5]
11706500352 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/3] [U_UU]
[================>....] recovery = 84.3% (3290015080/3902166784) finish=7 593.8min speed=1343K/sec
bitmap: 0/30 pages [0KB], 65536KB chunkmd0 : active raid1 sdb1[6] sda1[7] sdd1[4] sdc1[5]
4190208 blocks super 1.2 [4/4] [UUUU]unused devices: <none>
The resync=DELAYED is interesting. What does this mean?
Thanks again for you help.
- SandsharkMay 13, 2020Sensei
You have a multi-layer volume due to incremental drive size upgrades. Each layer is it's own RAID, and it can only sync one at a time. So the delayed one is waiting for the another to complete. The multiple layers may be contributing to the slower speed.
- StephenBMay 13, 2020Guru - Experienced User
[================>....] recovery = 84.3% (3290015080/3902166784) finish=7 593.8min speed=1343K/secThis is extremely slow (1 to 2 MB/s). Did you look at the smart stats with smartctl (smartctl -x /dev/sda (repeat for the other disks).
This is likely a consequence of the slowdown - the system isn't keeping up.
Ken6432-1 wrote:
May 12 21:46:38 Media-Backup sshd[3419]: Invalid user Retford from 192.168.1.1This is a little scary. Do you have ports forwarded to the NAS in your router? OR perhaps put it in the router's DMZ? If you have, then you should disable the forwarding (or put the NAS out of the DMZ).
StephenB wrote:
Ken6432-1 wrote:md127 : active raid5 sdb3[6] sda3[7] sdd3[4] sdc3[5]
I'm not sure what I am looking for. Nothing jumps out to me on /dev/sda, but that appears to be the 8Tb drive in the rightmost drive location. What would the address of the drive that is the third from the left? That is the one that was just changed.
I have not set anything on my router that would have to do with any of my NAS's. In fact, I don't remember setting anything except the basic out-of-the-box settings. I agree it is concerning. I updated my passwords to be safe.
