reyii
May 19, 2023Aspirant
Revert New Volume creation
Hello Community, I accidentally created a new volume through the admin web portal on a HDD that was part of my ReadyNAS, and now I can't access the files stored on that HDD anymore. ReadyNAS model...
- May 19, 2023
reyii wrote:
no RAID, this was a HDD formatted on another systems and was a NTFS regular partition on it.
ReadyNAS saw it initially as a disk that needed a new partition, or didn't quite understood what was there and presented it like a HDD that needs formatting. I only clicked on "new volume" and seem like ReadyNAS wrote that on it, now I can't see the data when I put the disk on the other Linux/Windows Server.
What happened is expected behavior, the NAS always destroys the disk content when create a volume.
You could try NTFS data recovery software, and see if it can get the data back.
reyii
May 19, 2023Guru - Experienced User
- reyiiMay 19, 2023Aspirant
I have no experience using NTFS recovery products, could you name a couple good options ?
thank you for taking the time to help Stephen 😃
- StephenBMay 19, 2023Guru - Experienced User
I don't have any recent experience either, so hopefully others will chime in.
Most of them seem to have a free download, so you can see what can be recovered before paying.
A couple I see (not recommendations, just google search results) are
- https://www.easeus.com/datarecoverywizardpro/
- https://www.cleverfiles.com/data-recovery-software.html
- https://dmde.com/
- SandsharkMay 19, 2023Sensei
FYI, you cannot put a drive containing files from some other type of unit into a ReadyNAS and access the files. That's why you were presented with that option. The prompt should have let you know you were destroying any existing files.
