Retired_Member's avatar
Retired_Member
Nov 25, 2018
RN 10200 Serialnumber shown is: N0NE000200000 correct is 3ERB49EM00A83; MAC-Address is not correct
I bought the RN10200 over ebay some days ago On the bottom i see Produkt: RN10200 Seriennummer 3ERB49EM00A83 MAC 28:C6:8E:36:FD:45 FW: V 6.1.8 It was bought 2014-12-07 and registered ...
  • mdgm's avatar
    mdgm
    Nov 26, 2018
    I’m no longer at NETGEAR.
    This is a problem most commonly seen on RN100/RN2120 when updating from pre-6.4.x firmware to 6.4.x or later but it could happen on other updates too.
    This is an easy problem for level 3 to attempt to fix, however as it’s a second hand unit purchasing support wouldn’t be an option.
    It does need to be fixed for you to be able to use ReadyCLOUD.
ProSupport for Business
