Anonymous
Nov 25, 2018RN 10200 Serialnumber shown is: N0NE000200000 correct is 3ERB49EM00A83; MAC-Address is not correct
I bought the RN10200 over ebay some days ago
On the bottom i see
Produkt: RN10200
Seriennummer 3ERB49EM00A83
MAC 28:C6:8E:36:FD:45
FW: V 6.1.8
It was bought
2014-12-07
and registered ...
- Nov 26, 2018I’m no longer at NETGEAR.
This is a problem most commonly seen on RN100/RN2120 when updating from pre-6.4.x firmware to 6.4.x or later but it could happen on other updates too.
This is an easy problem for level 3 to attempt to fix, however as it’s a second hand unit purchasing support wouldn’t be an option.
It does need to be fixed for you to be able to use ReadyCLOUD.
mdgm
Nov 26, 2018Virtuoso
Anonymous
Nov 27, 2018The NAS is connected via a switch to a Fritzbox 7490.
The Fritzbox assigns the NAS an IP address.
I have registered DNS Server 8.8.8.8 and also 8.8.4.4.
When I try to connect to READYCLOUD I get the message 24002000011.
The problem seems to be that the Nas also enters the Ethernet address 00: 50: 43: 02: 00: 00 as a serial number,
although on the device on the bottom this
Serial number 3ERB49EM00A83
and this
MAC address 28: C6: 8E: 36: FD: 45
are registered.
If I change the IP address to static, the serial number immediately changes to NONE000200000.
Then I get the message when I log in to READYCLOUD that the NAS is configured incorrectly.
Jochen
