Tommo2008
Feb 03, 2015Aspirant
RN 104 - USB Compatibility
Hi guys, I have recently purchased a 128GB USB Drive from MyMemory (http://www.mymemory.co.uk/USB-Flash-Dri ... rive---Red) however my problem is that when I attempt to plug it directly into my Nas...
RX
Feb 03, 2015Luminary
Tommo2008 wrote:
Ixa wrote: It seems that your 128GB USB Drive is not compatible with your NAS since you have also tried formatting it to FAT32...
I initially thought that but my friend has the same drive that works on his 102 so that's why I'm so stumped :-s
From what you have mentioned, just want to know... is the RN102 of your friend also runs on FW v6.2.2?
To further isolate the problem, is it possible for you to try inserting your own 128GB USB Drive to your friend's RN102 and check if it will detect it?
