Tommo2008
Feb 03, 2015Aspirant
RN 104 - USB Compatibility
Hi guys, I have recently purchased a 128GB USB Drive from MyMemory (http://www.mymemory.co.uk/USB-Flash-Dri ... rive---Red) however my problem is that when I attempt to plug it directly into my Nas...
Tommo2008
Feb 04, 2015Aspirant
Ixa wrote:
Tommo2008 wrote:
Ixa wrote: It seems that your 128GB USB Drive is not compatible with your NAS since you have also tried formatting it to FAT32...
I initially thought that but my friend has the same drive that works on his 102 so that's why I'm so stumped :-s
From what you have mentioned, just want to know... is the RN102 of your friend also runs on FW v6.2.2?
To further isolate the problem, is it possible for you to try inserting your own 128GB USB Drive to your friend's RN102 and check if it will detect it?
My friends RN102 is running 6.2.2, I havnt checked my drive on his 102 but I will when I can. We bought the same drives at the same time so I would assume it would work on there but ill let you know when I do.
