Maxter
Feb 10, 2018Aspirant
RN 422, OS 6.9.2, PLEX server "not available outside your network"
I have installed the PLEX app on my RN 422 running OS 6.9.2. The PLEX app works fine when accessed from inside my home network but I cannot get the Remote Access to work at all. The message I get is ...
- Feb 12, 2018
It's been quite a while since I enabled it, so I haven't run through the steps recently.
- is there a control on the remote access screen to enable remote access?
- is the port forwarded to the correct IP address in the router (you might need to reserve the NAS IP address, or even make it static)
- if the NAS already uses a static IP address, have you configured a DNS server as part of the NAS network configuration? Also check the subnet mask and the gateway address.
- is the remote access page showing that the server is expecting the port to be 34200?
On the last point, my own plex server expects the connection 34201 (because at one point I had a second server running that used 34200).
There are a couple of ways to deal with this, I just forwarded 34200 to port 34201
BTW, enabling the "advanced" mode on the remote access screen might give you some useful clues.
Maxter
Feb 12, 2018Aspirant
The "canyouseeme" link you provided reported port 32400 could be seen by the IP external port, but Remote Access section of the PLEX app still shows "Not available outside you network". Any sussgestion on how this can be fixed?
Feb 12, 2018Guru - Experienced User
