KDeWulf
Jul 07, 2019Aspirant
RN102 - additional disk not visible
Hi, I started running out of free space on ly RN102 (3TB disk, 90% used), so I bought an additional disk of 6TB. Inserted the disk; synchronisation started up. New disk is detected now, both disks ar...
bedlam1
Jul 07, 2019Prodigy
You need to buy/insert another 6TB disk I am afraid
- KDeWulfJul 07, 2019Aspirant
Thanks for your prompt response.
Bummer, unfortunately was not aware of this calculator before buying a disk. A shame to get this kind of useless capacity
Ideally I would have- partitioned 6TB in 2 blocks of 3TB
- Consider 1 block as 'critical' data, with back-up mechanism with the existing 3TB, remaining 3TB would be non-critical data, not backed-up
Alternative would be to work without RAID, just use full 3+6TB capacity and organize some kind of scheduled back-up / protection myself. Would that be possible?
