Napadave
Oct 13, 2015Aspirant
rn102 and tivo not working
So my new RN102 seems to be backing up my tivo correctly, however I cannot get the recordings to show up on the tivo my shows list. I see the RN102 and then I'm presented with three folders: All vid...
BrianL2
Oct 13, 2015NETGEAR Employee Retired
Hi Napadave,
Was this working before? Have you tried to rearchive the data from your TiVo on your ReadyNAS? Kindly check this article for more information.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
Napadave
no it is a new installation of the RN102.The backup/archiving to the RN102 seems to be working (the programs appear in the tivo folder under the name of the selected tivo box), however none of the programs on the RN102 are accessable on the Tivo
- BrianL2Oct 14, 2015NETGEAR Employee Retired
Hi Napadave,
Could you confirm the Firmware version running in your ReadyNAS?
Kind regards,
BrianL
NETGEAR Community Team- NapadaveOct 14, 2015Aspirant
6.4.0
Hi Napadave,
That seems strange. Have you tried to check with another ReadyDLNA enabled device (PC, mobile device, Smart TV) to see if the media files can be seen and played.
Looking forward to your response.
Kind regards,
BrianL
