Napadave
Oct 13, 2015Aspirant
rn102 and tivo not working
So my new RN102 seems to be backing up my tivo correctly, however I cannot get the recordings to show up on the tivo my shows list. I see the RN102 and then I'm presented with three folders: All vid...
Napadave
no it is a new installation of the RN102.The backup/archiving to the RN102 seems to be working (the programs appear in the tivo folder under the name of the selected tivo box), however none of the programs on the RN102 are accessable on the Tivo
BrianL2
Oct 14, 2015NETGEAR Employee Retired
Hi Napadave,
Could you confirm the Firmware version running in your ReadyNAS?
Kind regards,
BrianL
NETGEAR Community Team
- NapadaveOct 14, 2015Aspirant
6.4.0
- BrianL2Oct 14, 2015NETGEAR Employee Retired
Hi Napadave,
That seems strange. Have you tried to check with another ReadyDLNA enabled device (PC, mobile device, Smart TV) to see if the media files can be seen and played.
Looking forward to your response.
Kind regards,
BrianL
NETGEAR Community Team- NapadaveOct 15, 2015Aspirant
two things:
1. The media files can be seen on a PC on the network, however they ane .tivo files and are encrypted with the media access key of my tivo account and will not play on the pc (although I'm sure they would if I installed the proper playback software) but I dont want to play them on the PC, I want to play them back on the tivo.
2. There are three Tivo's on this network. The premiere and roamio have the same behavior described above (can see the RN102 but can't see any files). The Bolt doesn't even see the RN102
