overlook
Jan 12, 2014Tutor
RN102 basic questions
hello
Possible to connect to RN102 using SSH ?
I don't find add-on to do it.
RN102 uses the same OS as the RN312 ?
thanks,
thanks,
- ljungTutorYes, enable the SSH under System -> Settings -> Services in frontend/webinterface
Then login with username root and the same password you use for frontend.
Be aware that the manual says "If you enable SSH root access, NETGEAR reserves the right to deny you technical support." - overlookTutor
ljung wrote: Yes, enable the SSH under System -> Settings -> Services in frontend/webinterface
thanks
