dstsui
Apr 28, 2021Aspirant
RN102 broken after OS 6.10.4 update
My RN102 appears to be broken after updated to 6.10.4. Not sure which came first, I updated the OS to 6.10.4 and noticed very slow transfer speed when I copied hundreds of JPEG images from the SD car...
Apr 28, 2021Guru - Experienced User
Have you downloaded the log zip file, and looked for btrfs and disk-related errors in system.log and kernel.log?
What apps are installed?
- dstsuiApr 28, 2021Aspirant
I downloaded the log System_log-nas-36-1C-14-20210429-072924.zip this morning but I don't know exactly what to look for. The Log page in Admin looks fine to me; no error, no warning. By the way, the OS was updated on 25/4 6:39pm but the log was not retrieved until 29/4 4:7:29am so there is big chunk of information missing. The only app installed is Transmission.
- StephenBApr 28, 2021Guru - Experienced User
I redacted your download link (the full log zip shouldn't be posted publicly). But I did take a look.
kernel.log has a lot of errors on disk 1 (sda). For instance, this segement
Apr 27 10:30:23 nas-36-1C-14 kernel: ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 Apr 27 10:30:23 nas-36-1C-14 kernel: ata1.00: irq_stat 0x40000001 Apr 27 10:30:23 nas-36-1C-14 kernel: ata1.00: failed command: READ DMA EXT Apr 27 10:30:23 nas-36-1C-14 kernel: ata1.00: cmd 25/00:40:a8:6d:2b/00:05:67:00:00/e0 tag 26 dma 688128 in res 51/40:0f:d8:70:2b/00:02:67:00:00/e0 Emask 0x9 (media error) Apr 27 10:30:23 nas-36-1C-14 kernel: ata1.00: status: { DRDY ERR } Apr 27 10:30:23 nas-36-1C-14 kernel: ata1.00: error: { UNC } Apr 27 10:30:23 nas-36-1C-14 kernel: ata1.00: configured for UDMA/133 Apr 27 10:30:23 nas-36-1C-14 kernel: sd 0:0:0:0: [sda] tag#26 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE Apr 27 10:30:23 nas-36-1C-14 kernel: sd 0:0:0:0: [sda] tag#26 Sense Key : Medium Error [current] [descriptor] Apr 27 10:30:23 nas-36-1C-14 kernel: sd 0:0:0:0: [sda] tag#26 Add. Sense: Unrecovered read error - auto reallocate failed Apr 27 10:30:23 nas-36-1C-14 kernel: sd 0:0:0:0: [sda] tag#26 CDB: Read(10) 28 00 67 2b 6d a8 00 05 40 00 Apr 27 10:30:23 nas-36-1C-14 kernel: blk_update_request: I/O error, dev sda, sector 1730900184 Apr 27 10:30:23 nas-36-1C-14 kernel: md/raid1:md127: sda3: rescheduling sector 1721199976I suggest powering down the NAS and testing it in a Windows PC (either connected with SATA or a USB adapter/dock) with Lifeguard.
Alternatively, you could try rebooting the NAS w/o it, (leaving disk 2 in slot 2), and see if you get a more normal speed.
When you replace the disk, avoid the WD20EFAX - it is an SMR drive. A Red Plus drive (another WD20EFRX or WD20EFZX) would be fine.
StephenB wrote:
dstsui wrote:I downloaded the log System_log-nas-36-1C-14-20210429-072924.zip this morning but I don't know exactly what to look for. The Log page in Admin looks fine to me; no error, no warning. By the way, the OS was updated on 25/4 6:39pm but the log was not retrieved until 29/4 4:7:29am so there is big chunk of information missing. The only app installed is Transmission.
Do you think the NAS will boot up with Disk 1 taken out? Did you observe similar errors in Disk 2? How likely do you think the problem with the NAS hanging when reading/writing multiple files is related to errors in Disk 1?
What is preferred way of posting a file (other than an image) on the forum?
