dstsui
Apr 28, 2021Aspirant
RN102 broken after OS 6.10.4 update
My RN102 appears to be broken after updated to 6.10.4. Not sure which came first, I updated the OS to 6.10.4 and noticed very slow transfer speed when I copied hundreds of JPEG images from the SD car...
Apr 28, 2021Guru - Experienced User
Have you downloaded the log zip file, and looked for btrfs and disk-related errors in system.log and kernel.log?
What apps are installed?
dstsui
I downloaded the log System_log-nas-36-1C-14-20210429-072924.zip this morning but I don't know exactly what to look for. The Log page in Admin looks fine to me; no error, no warning. By the way, the OS was updated on 25/4 6:39pm but the log was not retrieved until 29/4 4:7:29am so there is big chunk of information missing. The only app installed is Transmission.
- StephenBApr 28, 2021Guru - Experienced User
I redacted your download link (the full log zip shouldn't be posted publicly). But I did take a look.
kernel.log has a lot of errors on disk 1 (sda). For instance, this segement
Apr 27 10:30:23 nas-36-1C-14 kernel: ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0 Apr 27 10:30:23 nas-36-1C-14 kernel: ata1.00: irq_stat 0x40000001 Apr 27 10:30:23 nas-36-1C-14 kernel: ata1.00: failed command: READ DMA EXT Apr 27 10:30:23 nas-36-1C-14 kernel: ata1.00: cmd 25/00:40:a8:6d:2b/00:05:67:00:00/e0 tag 26 dma 688128 in res 51/40:0f:d8:70:2b/00:02:67:00:00/e0 Emask 0x9 (media error) Apr 27 10:30:23 nas-36-1C-14 kernel: ata1.00: status: { DRDY ERR } Apr 27 10:30:23 nas-36-1C-14 kernel: ata1.00: error: { UNC } Apr 27 10:30:23 nas-36-1C-14 kernel: ata1.00: configured for UDMA/133 Apr 27 10:30:23 nas-36-1C-14 kernel: sd 0:0:0:0: [sda] tag#26 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE Apr 27 10:30:23 nas-36-1C-14 kernel: sd 0:0:0:0: [sda] tag#26 Sense Key : Medium Error [current] [descriptor] Apr 27 10:30:23 nas-36-1C-14 kernel: sd 0:0:0:0: [sda] tag#26 Add. Sense: Unrecovered read error - auto reallocate failed Apr 27 10:30:23 nas-36-1C-14 kernel: sd 0:0:0:0: [sda] tag#26 CDB: Read(10) 28 00 67 2b 6d a8 00 05 40 00 Apr 27 10:30:23 nas-36-1C-14 kernel: blk_update_request: I/O error, dev sda, sector 1730900184 Apr 27 10:30:23 nas-36-1C-14 kernel: md/raid1:md127: sda3: rescheduling sector 1721199976I suggest powering down the NAS and testing it in a Windows PC (either connected with SATA or a USB adapter/dock) with Lifeguard.
Alternatively, you could try rebooting the NAS w/o it, (leaving disk 2 in slot 2), and see if you get a more normal speed.
When you replace the disk, avoid the WD20EFAX - it is an SMR drive. A Red Plus drive (another WD20EFRX or WD20EFZX) would be fine.
- dstsuiApr 28, 2021Aspirant
StephenB wrote:
dstsui wrote:I downloaded the log System_log-nas-36-1C-14-20210429-072924.zip this morning but I don't know exactly what to look for. The Log page in Admin looks fine to me; no error, no warning. By the way, the OS was updated on 25/4 6:39pm but the log was not retrieved until 29/4 4:7:29am so there is big chunk of information missing. The only app installed is Transmission.
Do you think the NAS will boot up with Disk 1 taken out? Did you observe similar errors in Disk 2? How likely do you think the problem with the NAS hanging when reading/writing multiple files is related to errors in Disk 1?
What is preferred way of posting a file (other than an image) on the forum?
Will the NAS boot up with disk 1 taken out? Did you observe similar errors in disk 2? How likely is the NAS hanging up when reading/writing multiple files caused by errors in disk 1?
Re HDD dock, do you mean something like this? What is Lifeguard? Can Windows read the files directly?
- StephenBApr 29, 2021Guru - Experienced User
Yes
No, and it won't mount the disk. But Lifeguard will see it, and you can test it.
If you boot the NAS with just disk 2, and then later on want to reinsert disk 1: You will need to resync disk 1, which rebuilds it's contents from scratch. So you might as well also run the destructive "erase disk" (might be called "write zeros") test as well as the non-destructive tests I suggested.
If you want the option to reinsert disk 1 w/o resync, then you need to keep the NAS powered down until you test the disk. But given the errors, I'd just replace the disk.
dstsui wrote:
What is Lifeguard?
Western Digital's diagnostic utility. You can download it from here: https://support.wdc.com/downloads.aspx?p=3
Though it looks like they've replaced it with a newer utility ( https://support.wdc.com/downloads.aspx?lang=en&p=279 ), so you could try that one. But Lifeguard will still work.
