dstsui
Apr 28, 2021Aspirant
RN102 broken after OS 6.10.4 update
My RN102 appears to be broken after updated to 6.10.4. Not sure which came first, I updated the OS to 6.10.4 and noticed very slow transfer speed when I copied hundreds of JPEG images from the SD car...
mdgm
Apr 29, 2021Virtuoso
mdstat.log shows info on the RAID levels more concisely
md0 is the 4GB root volume and uses RAID-1. The system will still boot if a disk is removed however any RAID-0 data volume using that disk won’t be able to be mounted as the RAID array won’t be able to be started.
dstsui
Apr 29, 2021Aspirant
The following is extracted from mdstat:
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md127 : active raid1 sda3[0] sdb3[1]
1948662784 blocks super 1.2 [2/2] [UU]
bitmap: 0/15 pages [0KB], 65536KB chunk
md1 : active raid1 sda2[0] sdb2[1]
523712 blocks super 1.2 [2/2] [UU]
md0 : active raid1 sda1[0] sdb1[1]
4190208 blocks super 1.2 [2/2] [UU]
If md127 is the data volume (size appears correct), it is RAID1. RAID0 does not appear in the log.
