Benchster
Dec 04, 2019Aspirant
RN102 Firmware Update Failed 6.9.5
Hi, I'm hoping someone will be able to help me. My ReadyNAS 102 said on the admin page that it needed to upgrade the firmware [I can't remember what the existing firmware was but it was quite early ...
- Dec 04, 2019
Update: Since the above I have now solved the issue by installing the 6.2.5 firmware on a USB recovery stick and then using the automatic firmware upgrades to get the firmware completely up to date. Be careful doing this though as I believe you have to be careful when using this method.
Benchster
Dec 04, 2019Guru - Experienced User
Thx for updating us on the solution that worked for you.
- BenchsterDec 04, 2019Aspirant
No problem!
All working fine now so very pleased.
