Wombo24
Aug 08, 2019Guide
Firmware update 1.0.0.44 Fails
An onscreen prompt appears advising "A router firmware upgrade is available".
Attempting to update the firmware from Netgear server continually results in:
"Downloading and updating the language table"
Followed by error : "Failed to update GUI language file "
Firmware update details:
Current GUI Language Version: 1.0.0.32_2.1.38.3
New GUI Language Version: 1.0.0.44_2.1.38.3
Current Firmware Version 1.0.0.32
New Firmware Version 1.0.0.44_1.0.60
Release Notes:
1. [Bug Fix] Fixed security issue.
2. [Bug Fix] Fixed security issue.
Hi, All,
Please try again the firmware update and let us know of the result. This should be fixed by now.
Blanca
Community Team
- GraemeMcAspirant
I have the same issue and nothing changes the failed outcome on any browser. Waiting "patiently" for a fix from Netgear
- SnuckAspirant
- Blanca_ONETGEAR Employee Retired
Hi, All,
We are investigating on this. We will get back to you for any updates.
Blanca
Community Team - Ender76Initiate
I too am having this issue and have been for several months. Fails to install the language file from the new firmware 1.0.0.44_1.0.60 via auto update. I am unable to do a manual update as the Firmware for these smart cradles are nowhere to be found for download.
Hi, All,
This has been brought up already to engineers. I will get back to you guys for any updates.
Blanca
Community Team - Blanca_ONETGEAR Employee Retired
Hi, All,
Blanca
Community Team- Wombo24Guide
Hello Blanca,
Yes the update worked successfully and I am now at V1.0.042_1.0.60
Thanks for your help getting that resolved.
Cheers,
John
Blanca_O If this is Solved as you say, then why is my modem saying their is an update still but when checked it says no update, please refer to attachment, clearly this is still an issue.
This is not solved for m any of us, why is this marked as solved?
- sanpasAspirant
- UC74Guide
- LlamaLarryLuminary
Same thing for me, same, US SKU as the others:
A new version has been found. Do You want to upgrade to the new version now?
Current GUI Language Version: 1.0.0.34_2.1.38.3
Current Firmware Version 1.0.0.34
I try updating and get:
Downloading and updating the language table, please wait for approximate one minuteā¦
Followed by:
Where is the standalone firmware file so we can update manually?
Hi, All,
Thank you for providing your device's SKU. I am checking this with our engineers. I will provide update once new information will be availableRegards,
Blanca
Community Team- GkespyTutorI'm having the same issue. Says upgrade available. I'm at 1.0.0.34. Can't download the language file and fails. Mine is a DC112A-100NAS.
