Lovenupload
Jul 29, 2022Aspirant
RN102 firmware update
Hi all,Hoping for some help. I have the RN102. currently running firmware 6.2.5. Yes that old. Ever since I've owned it I have had no luck updating the firmware. I have downloaded 6.5.2 and tr...
- Jul 30, 2022
Lovenupload wrote:
[1262]: Error: Connection failure: Connection refuses.
Is this relevant?Could be, it depends on what connection it was (and why).
Can you look at volume.log? Scroll down until you get to the df -h and df -i sections. I'd like to see the two entries for /dev/md0:
=== df -h === Filesystem Size Used Avail Use% Mounted on /dev/md0 3.7G 829M 2.7G 24% / === df -i === Filesystem Inodes IUsed IFree IUse% Mounted on /dev/md0 1048576 14418 1034158 2% /
Jul 29, 2022Guru - Experienced User
Lovenupload wrote:
I have downloaded 6.5.2 and tried to manually do it. It says its updating and gets to about halfway up the blue update bar then the blue bar shoots all the way to the end.
The NAS then reboots, but I'm still on Firmware 6.2.5.
Any ideas?
Is the NAS able to connect to the internet? If you are using NTP (automatic time sync) you can download the log zip and look for NTP time adjustments in connman.log. If those are present, then it is able to reach the internet.
Also, if you have a scratch (spare) disk, you could try powering down the NAS, removing the current disks (labeling by slot), and then do a factory install with the spare disk inserted. Then try the manual update with the spare.
Lovenupload
Jul 30, 2022Aspirant
Ok. So I've found out my rn102 is not connected to the internet. It is accessible through my network though.
I don't run a Netgear router, so how do I set up a different router to let the NAS go online.
Also I am not great at computers and networking. So be kind. Thanks
