Lovenupload
Jul 29, 2022Aspirant
RN102 firmware update
Hi all,Hoping for some help. I have the RN102. currently running firmware 6.2.5. Yes that old. Ever since I've owned it I have had no luck updating the firmware. I have downloaded 6.5.2 and tr...
- Jul 30, 2022
Lovenupload wrote:
[1262]: Error: Connection failure: Connection refuses.
Is this relevant?Could be, it depends on what connection it was (and why).
Can you look at volume.log? Scroll down until you get to the df -h and df -i sections. I'd like to see the two entries for /dev/md0:
=== df -h === Filesystem Size Used Avail Use% Mounted on /dev/md0 3.7G 829M 2.7G 24% / === df -i === Filesystem Inodes IUsed IFree IUse% Mounted on /dev/md0 1048576 14418 1034158 2% /
Lovenupload
Jul 30, 2022Aspirant
Right. Yes we have some results
[1103]: ntp: time slew +0.018225 s
So I'm online.
Last log says
Is this relevant?
So I'm online.
Last log says
Is this relevant?
Jul 30, 2022Guru - Experienced User
Is this relevant?
=== df -h ===
=== df -i ===
- LovenuploadJul 30, 2022AspirantHi Stephen.
I don't know what's happened, but I tried to update the firmware again to 6.5.2 manually and it did it. From then on everything seemed to work. Now at 6.10.7
I'd like to thank you for your patience with me.
It may have been Firefox settings as the Netgear web UI needed permission . But i did that to start with, so I'm not sure.
Thanks again for your help - StephenBJul 30, 2022Guru - Experienced User
Lovenupload wrote:
I don't know what's happened, but I tried to update the firmware again to 6.5.2 manually and it did it. From then on everything seemed to work. Now at 6.10.7Great!
- dcheitelJan 19, 2025Aspirant
I am currently having the same problem. have tried to manually update to 6.5.2 over and over but no luck so far
