Parnassus
Jul 02, 2020Aspirant
RN102 shows up as network drive but can't access admin
I'm staying at a place temporarily and setting up my ReadyNAS 102 as well as some other devices, and I'm having some issues connecting to the NAS. I don't have admin access to the router. -On a l...
- Jul 03, 2020
Did you have a static IP address assigned to the NAS that may now be outside the subnet of the router in your new location? RAIDar is the best way to find that out, and an OS re-install can solve it (it resets the NAS to use DHCP). Just be sure to select OS Re-install, not Factory Default.
Sandshark
Jul 03, 2020Sensei
Parnassus
Jul 04, 2020Aspirant
Thanks guys, this was exactly the problem. I used RAIDar which showed that the device was on a static IPv4 from my previous network. Doing the OS reinstall fixed it and I can now access and set it up properly for this place.
- StephenBJul 04, 2020Guru - Experienced User
Great. Reserving the IP address in the router (instead of assigning a static IP address) is one way to prevent this from happening again.
